Hey guize, I've been on the forum for a couple months now and know the bunch of you could give me some help.
I grabbed a '99 YZ80 before my brother had a chance to short change it for pennies on the dollar.
I stripped it down to frame, painted it a nice Yamaha Blue, and did some other repairs.
I rebuilt the engine as it didn't run; new crankcase seals, shifter seal, and top end gasket & o-rings. Piston wasn't in terrible condition, and the ring wasn't seized in the sides.
Cylinder itself had wear, but nothing worth mentioning.
I replaced everything to spec torque, and even did a leak down test. Only lost about 1-3 PSI a minute. I only could get 60PSI off a tester at WOT up to 8 kicks.
It has spark when tested outside of the cylinder, but won't start up. I've tried bump-starting, and removed the closed-circuit shorting of the kill switch out of the equation. New spark plugs, properly measured 32:1 mixture as stated in the book.
Starter fluid doesn't start it either; verifying it isn't a fuel issue.
Any ideas? Thanks!
Any ideas? Thanks!
