new bolts all around. Cleaned up OEM nuts and washers on the buffer wheel.
mte78 · Registered Joined Feb 8, 2018 · 131 Posts Discussion Starter · #21 · 28 d ago Only show this user new bolts all around. Cleaned up OEM nuts and washers on the buffer wheel.
mte78 · Registered Joined Feb 8, 2018 · 131 Posts Discussion Starter · #22 · 28 d ago Only show this user
mte78 · Registered Joined Feb 8, 2018 · 131 Posts Discussion Starter · #23 · 28 d ago Only show this user Cleaned up the entire motor and wiring harness today. While at it removed the PAIR (2.5 lbs of junk). Replaced the plugs and filter. Went ahead and did the air box mod. While at it, cut the plastic trunk off in prep for the Sharkskinz SBK tail.
mte78 · Registered Joined Feb 8, 2018 · 131 Posts Discussion Starter · #24 · 28 d ago Only show this user Once the Nitron shock arrives, I will remove the swingarm to clean it up and replace the bearings. New Ti nuts and bolts arrived for the shock, links, and joint today.
A ACTAngler · Premium Member Joined Dec 23, 2009 · 105 Posts #25 · 28 d ago Only show this user Looks like a "no expense spared" build!
mte78 · Registered Joined Feb 8, 2018 · 131 Posts Discussion Starter · #26 · 28 d ago Only show this user Does anyone have these two castle nut tools that I can borrow?
TwistedMister · Premium Member Joined May 28, 2003 · 7,340 Posts #27 · 28 d ago Only show this user find a piece of hardwood, tap to unlock it and spin em off
mte78 · Registered Joined Feb 8, 2018 · 131 Posts Discussion Starter · #28 · 27 d ago Only show this user I tried that and a castle nut spanner. Applied heat too. It’s on their plenty good. I found the required sockets on Titan Classics out of the UK.
mte78 · Registered Joined Feb 8, 2018 · 131 Posts Discussion Starter · #29 · 27 d ago Only show this user Cleaned up the cluster and buffed out the plastic. Installed a NOS carbon fiber tach cover.
mte78 · Registered Joined Feb 8, 2018 · 131 Posts Discussion Starter · #30 · 24 d ago Only show this user Cool fairing stay. Looks like billet mounting points. Left hand switches came in too.
mte78 · Registered Joined Feb 8, 2018 · 131 Posts Discussion Starter · #31 · 22 d ago Only show this user Do these swingarm pivots come off or are they part of the frame? If so, what size socket is this?
mte78 · Registered Joined Feb 8, 2018 · 131 Posts Discussion Starter · #32 · 22 d ago Only show this user Swingarm was filthy. I also cleaned up the shock clevis, knuckle, and chain guard. New Ti nuts and bolts for the rear suspension along with shorter dog bones to raise the rear.
mte78 · Registered Joined Feb 8, 2018 · 131 Posts Discussion Starter · #33 · 22 d ago Only show this user Attachments 35736120-3B78-4AFA-893C-19FA1ED25E01.jpeg 1.7 MB Views: 4 A8FEE9DE-8403-4C5F-802A-C83C9D1888F8.jpeg 1.5 MB Views: 5 293FBA1C-E79D-4FF7-B698-EFBA46ED807E.jpeg 1.7 MB Views: 5
mte78 · Registered Joined Feb 8, 2018 · 131 Posts Discussion Starter · #34 · 22 d ago Only show this user
mte78 · Registered Joined Feb 8, 2018 · 131 Posts Discussion Starter · #35 · 22 d ago Only show this user Clean up the best I could. New Ti hardware and lift spools.
mte78 · Registered Joined Feb 8, 2018 · 131 Posts Discussion Starter · #36 · 22 d ago Only show this user Cleaned up the radiator. Looks like new inside. Added Ti bolts and carbon fiber cap.
mte78 · Registered Joined Feb 8, 2018 · 131 Posts Discussion Starter · #37 · 21 d ago Only show this user 2mm offset swingarm pivots with Ti nuts and bolts:
mte78 · Registered Joined Feb 8, 2018 · 131 Posts Discussion Starter · #38 · 21 d ago Only show this user Refreshed knuckle. Shorter links. Custtom cut Ti nuts and bolts (rear suspension).
TwistedMister · Premium Member Joined May 28, 2003 · 7,340 Posts #39 · 21 d ago Only show this user sheesh this thing is gonna be a bad little SRAD
mte78 · Registered Joined Feb 8, 2018 · 131 Posts Discussion Starter · #40 · 21 d ago Only show this user Rear Brembo with billet under slung bracket and new brake line:
