I just finished installing the timing chain, and do the timing. With all the posts and the manual it was pretty easy, the only problem I had was with the stock tensionner. I only made a few turn on the spring so that the mounting screw could engage a few threads and then I screw it all the way in place with my allen wrench. The timing chain was really really tight because of that. I removed the tensionner and turned the piston all the way in so that i could screw the 2 mounting bolts on the engine by hand before applying tension on the chain.
I hope I didn't damage anything by putting too much tension on the chain!?
With this tensionner do I need to check/adjust the tension on the chain ?
Other than that everything went pretty good, I turned the engine by hand a few times everything was smooth and i checked the timing again 2 times.
