what will cause a radiator fan from working. If I let my bike sit and idle it will start overheating. Then fluid will start leaking from the radiator hoses. The fan never turns on. I put another fan on the radiator and that dosnt help either.
Bearded Admin call him Grizzly
check the fuses, or you might need a new temp sensor
Sounds like the fan switch/sensor has gone faulty.
I found out what it is. It is the thermo-sensor. Its not fucking plugged up!! the outlet was just hanging there. But there is one more problem. My last radiator had an outlet on the radiator for plug in, this radiator has no outlet! The local shop says there can be one on the motor but there not sure where. I would have thought maybe this one broke off but there is no breaks on the radiator. It was just not made with an outlet. Where could this outlet be??
