Do you think my D&D full system for my 97 gixxer 750 (carbed) would eventually fit the 99 gixxer 600? any ideas?
it might physically fit, but the pipe was probably designed to flow the spent gasses from a 750 cc motor, rather than a 600cc motor....there is a definate difference in these two concepts.....sell it on ebay and get the exact application u need
You can probably get away with it. You may just need to open up the ports on the exhaust side a little and then use aftermarket cams to get full advantage of it. Chances are the 750's not going to have that much larger exhaust anyways. I'd just try it.
I put on a FULL Akra that was designed for the 750 and all I had to do was tinkle with the jets..
YES it will work fine.
