IM THE BRONZE
Hey guys, what is the normal compression for a 96 gsxr 1100?
As per manual, the standard is between 170lbs-199lbs.
If it's low check valve adjustment and look for tight valves.
If low and valves are good, add some oil in the cylinders and check comp again.
If it raises after oil, you got stuck or worn rings/cyl. issues.
