Had the bike for a couple of years now, its standard apart from a full Yoshi pipe.Been running just fine up untill the other day.I was out for a blast on a nice sunny evening, had been out for around an hour , gave it a bit stick along the local dual carrigeway fine up through the box when i was in 5th going to 6th, lost power and it wouldnt pull in top. At firs i thought it was fuel so i put it on reserve but no difference. Now the bike starts and runs fine at lower revs, but when on the road it starts to to misfire and run like on 3 pots when the revs rise above about 6 thou, or you give it a handfull. Checked the plugs and they seem ok but perhaps ill change them and see what happens,could it be a carb diaphram or would this affect the running at all revs.Any ideas would be helpful to save me going round in circles.
perform a check on the signal generator
I suggest you put it in a raft and float it over to me so I can look at it.
JK second the generator
EDGE_
