I know, I know, I spent quite a bit of time looking around and searching the forums, but was unable to find a definitive answer.
Will a 1100w rear wheel fit the stock swing arm on my 93 750w? I checked out the dealer parts pages and compared part numbers, and from what I see it should be a straight bolt on, however, we all know what happens when you assume......
Spacing, caliper and/or rotor clearance issues?
Somehow, my rear wheel has developed a serious flat spot during the winter months, and I need a replacement. (falling off the hoist probably didn't help)
Thanks guys
I had an 1100W wheel on my 6/11 w the stock 600W arm;its been 20yrs so I forgot if any spacers,etc needed to be swapped out. But it did fit w no clearance issues.
Hope this sort of helped
yes, any 1100W rear wheel will fit any 750W. the 600W used a different rear wheel, with different sprocket, and sprocket side spacer.
