1 - 15 of 15 Posts
Was just reading another thread about upgrading Gixxer 1000s to have 929rr front calipers. Has anyone done this to a 96-99 gixxer? I'd really like to do it, but don't know if it will work the same as on the 1Ks. Thanks!
If I remember correct... From other posts we have found that it isnt a direct bolt on... Not to sure... But you could get the same thing from a set of 4 pots off of a 97-00 gsxr 600.. They work very nice...
do the 4pots make that much of a difference compared to the 6? i'm looking for the best brakes up front that i can get for it.
Well first off... Why do you want THE BEST YOU CAN GET??? Are you racing?? Stunting??
Anyhow... Do you have SS lines?? What pads?? What fluid???
I think that the 4 pots are the best for the money... But you could go with something like 8 pot brembo (sp) or something...
Discussion Starter · #6 ·
no racing, just stunnin with occasional twisties. Currently it has steel braided lines and the rest is stock. OEM pads.
Maybe you should try HH pads... They make a BIG change in the bike..
Also the 4 pots from the 600 are great!! use them with some HH pads and your set.
I <3 Item 9
I'll be installing a set of 929 calipers in the next week or so. They are currently in transit to me.
I can't wait to see what the difference is, if there is any
It's not a direct bolt on, but it you have any mechanical ability with modifying things then it shouldn't be a problem. I know I'll have no problems
Originally posted by skidmark:
ya, but I'm vain and the 929 calipers are gold
<font size="2" face="Verdana, Arial">Hey more power to you!!
I know how it is to have something that looks good...
I just had the ones from a 600 and it didnt cost me anything more then fluid to change them..
Discussion Starter · #11 ·
cool, thanks for the advice guys, i'll start looking for some 4pots of a 600.
But curious, why would the 4pot 600 brakes be better than the 6pot 750s?
the 4 pot has more piston surface area... This would make more brake power to the rotor, even if it has less pad area...
I also think it might have something to do with the smaller pads cooling off faster?? not to sure.
What would you reccommend for fluid???
Also, aren't HH pads really hard on rotors? or is that the sintered ones?
thanks
thanks
HH pads are sintered...
I have been running HH pads for about 40K miles and I still have my stock rotors... Dont worry about it..
For fluid, easy to find stuff... Motul RBF600...
The brake pads that are the hardest on rotors are the stock items. My rear has been warped since I got it and the stock pads have eaten all the meat from the disc. Bendix are also a little too much like sandpaper for my liking as a set of those put a lip on my fronts. Since I've had the EBC they sound like they are grinding the disc away but don't seem to be. I think it's cause the pads are much softer and wear first
1 - 15 of 15 Posts
