Having trouble with spacing and caliper fitment.I have a bandit hanger for the 240 rotor but it still won,t let the caliper mount,it looks like if i grind some material off the two mounting holes it should fit,i would rather not do that if possible.Any advice on this?
are you referring to a "water-cooled" rear wheel? in the states, 1992's were still oil-cooled, which makes a big difference in rear wheels and spacers.
if you are trying to fit a "water-cooled" rear wheel, then use a bandit 1200 brake caliper hanger, 240mm rear rotor, and a bandit 1200 right hand side spacer. it is a tight fit, but will fit with some work. no grinding is necessary.
post a foto of the rear wheel if you are unsure. here is one of my first gen 750's with a water-cooled rear wheel as a reference. it fits.
Found a 90 750 hanger and with the 92 spacers it fits perfect,thanks for the advice everyone.Hopefully this will be useful info for somebody else sometime.
