I'm thinking of putting a 92 GSXR 750 curved oil cooler into my 87 1100. The cooler looks like it will fit, but it requires different hoses for it's different fittings.
Will the 750 oil cooler hoses work on my 1100, or will I need the later model 1100 oil lines?
Thanks,
Jerry
I dummy fitted one up on mine and from memory it interfered with the fairing possibly forks also on full lock
I have a later model curved cooler on my 750 slabby, it has AN fittings welded on. but as far as clearance goes, it clears everything, if you're using OEM mid panels you might have to trim them though
