Hi All!
Does anyone know if the fork uppers from the 92-93 GSX-R600 can be swapped into 91-92 GSX-R750 forks?
The upper and lower tube diameters are 50mm and 54mm, respectively, and the fork caps and upper adjusters are the same part numbers, but the dampers are different part numbers and the fork tube lengths are probably different. I can't find much info on GSX-R600 fork dimensions, but I think they're longer than the 750 forks.
I have several sets of 750 forks, but I'd like to have a one-piece upper for the forks that are going on a bike I'm building.
Thanks in advance for any info you can provide!
