My 86 GSX-R 750 stock carbs suck (individual K&Ns, full Yoshi pipe, and Factory Stage 3 jet kit). After years of tuning I give up. Can someone list the model and year motorcycles that have compatible (and better) carbs and possible sources (I have seen some on e-Bay). I'm looking for carbs that would be an easy swap (no mods required). Thanks in advance.
Rob Robinette
yes, the stock 31mm carbs suck the big one.....good replacements are the 34mm carbs from the 87 750 or 86-88 1100, and 36mm slingshots from the 88-89 gsxr750 or early 90's katana 750.
the 34's should snug right into the '86 intake boots, but the 36's will be fairly difficult to get in - ideally you'd want the intake boots to go with the 36's if you decide to get them.
keep in mind, the 87 750 has slightly larger intake ports, so they're a bit better suited for the 34's and 36's (especially the latter) than the 86 head...
