are the 750 and 600 rear shocks any different. i was wanting to put a 750 rear shock on my 98 600. someone said they made the back end sit a little higher. is that true. any advice?
Here is your "R"
Same if its the same year, but if you put a 750 out of a 2000+up then yes I believe there taller. If you want more rear lift just add washers under the top mount. Look in this section on raising the rear
