I have 06 750 Gsxr . I have checked everything under the seat to fuses even went to the manual to check connections and fuses . Battery and fuses are good . i cant seem to figure out the problem with the bike .
I will assume that "no power at all" means the dash, lights, etc. don't come on. Have you tested the 30A main fuse?
Hand-Eye Coordinator
When you say battery is good, you mean well above 12.5V at rest, right? When you say fuses are good, you used an ohmmeter or continuity test, right?
Have you looked to see that the terminals are on the correct side and that the battery leads are solidly connected on both sides?
With the key on and using a voltmeter, you confirm that there is no power to anywhere on the machine? Turn the key on and test the voltage between the poles on the starter relay.
