Does anyone know if these are different in spark characteristics? I just put a 750 motor in my 600 frame, and I didn't have the coils for the 750 with me. I put the 600 ones in just to test, and the bike isn't running perfectly. It starts just fine, but sounds like there is a misfireing effect. The engine is not radling or rocking at all and the engine feels very smooth if I sit on it, or feel the airbox, or feel the engine.
I drained the 87 gas and put 93 in there so I know its not gas related.
I swapped the 600 and 750 ecu so that 750 is the one in the bike.
I tried my 600 map sensor and the problem did not go away.
I unplugged and connected 1 injector at a time and the engine got worse each time, so it would seem that these are all working.
I did the same with coils and the same thing as above happened.
Only thing left for me is to check the cam timing because I know what that sounds like when it's off and it does sort of have that sound to it.
Monday I put in new plugs and the correct coils, and hopefully this fixes it! Any suggestions?
