Hello i am going to change 530 OEM chain with 525 , but problem is that cant find sprockets for 525 chain . In vortex and RK officlial website there is only 530 and 520 option for my bike
Does anyone knows can i find 525 sprockets or in my model there is not chance to use 525 chain with sprockets and i have to chose 530 or 520 ?
Check out JT sprockets or Sunstar. If you do find them and have the part number Amazon is the best place I have found for best prices. Save about $40-50 through Amazon
You are right amazon is best place for sprokets and chain , i try to find on JT and it have also 520 and 530 😞 i dont know why they dont have 525 on my model. For example k8 have the 525 but from 2009-2018 there is only 520 and 530
K1-K8 1000 sprockets fit to 2000-2010 600/750 bikes. That's why there is 525 option also for 1Ks. Maybe newer are not interchangeable and there's no point in making 525 sprockets only for 1Ks.
My 2012 AFAM catalog lists 525 steel front and rear plus 525 aluminum rear for K9-L2. Possibly that's the same as yours. Front 22901-xx (16-17), rear steel 12815-xx (42-47), rear aluminum 13815-xx (41-47).
In a quick search, the hits were all out of Europe and Russia.
Here are some Superlite 525's in the US. I have distant memory of cracking problems and disputes with Motomummy. You're on your own there.
YOUR MODEL K8 IS AVAILABLE HERE IN THE USA....SUPERSPROX Lasts 3 (three) times longer than ANY OTHER SPROCKET (front or rear)
https://www.supersproxusa.com/categories.php
As his title states, he has an L4. The 525 is relatively uncommon and, as best I can tell, Supersprox does not make a 525 sprocket for it.
The steel teeth lead to longer life but they, like all others, can still break:
About this Discussion
5 Participants
BillV
Full Forum Listing
