Recently I installed a set of 36 mikunis- which work great. One part I am missing however is the choke cable. The connection to the choke appears to be a cable connection, so my question is: did the bikes that came stock with 36's have a choke "cable" and where did the plunger for it mount? Did the plunger sit down by the carbs like the one on my 29's or did it go elsewhere like the dash? If you could tell me which years had the cable that would fit these carbs then I can order the cable-plunger assembly. I've also though about just buying a generic cable plaunger from Pepboys and routing it up to my dash area.
While I'm on the topic of cables- my bike is set-up with the stock throttle cable assembly with a single cable. What would you all recommend as an upgrade and where would I find it? Lockhart has push-pull type throttles which won't fit my carbs.
Youth and talent are no match for age and treachery!
[This message has been edited by Talisian (edited 03-22-2001).]
