Vendor
Our full system just went to production this week and is about two weeks out. We have a "Cat Back" exhaust ready to go now. This doesn't touch or alter the OEM cat converter system but removes the giant silencer off the bike. Coupon code "insta" is open for discounts. Thank you.
https://www.gravesport.com/products/suzuki-gsxr-1000-cat-back-slip-on-exhaust-2017.html
Graves Motorsports 2017 GSX-R 1000 Cat Back Carbon Slip-on Exhaust. This Slip-on retains your factory catalytic converter and is new from the ground up with record breaking race developed features. Graves' precise engineering develops precision products that are designed to outlook, outperform and outlast the competition. This product does not alter or remove the factory OEM catalytic converter.
New Silencer Design Featuring: Carbon Fiber Sleeve with Titanium End Cap. Strapless design mounts without the use of straps. This design not only streamlines looks but saves 4.4 lbs pounds over the stock can alone!
Advanced welding process showcases laser precision welds. No over-sized welds that cause excessive heat.
Mandrel Bent Titanium Tubing
Everlast packing materials
Carbon Fiber with Titanium End Cap
Graves Exclusive Superbike Inspired Sound
Sound :
Stock Exhaust at Idle 81 db at 5000 rpm 87.5 db
Graves Slip-on at Idle 90 db at 5000 rpm 97.5 db
Weight
Stock pipe weight 7 lbs
Graves Slip-on 2.6 lbs
