Hi,
I was in the process of replacing the stock air filter with a K&N, what I thought was a 30 minute job at most turned into a nightmare. The bolt for one of fuel rails on the airbox was the last thing I had to remove before I was going to open up the airbox and drop in the new air filter. The bolt spins and does not back out. I tried lifting the bolt head and the fuel rail bracket while turning the bolt to no luck. below is a picture of the bolt, its the silver one on the airbox. Looking at the other bolt that I was successfully able to take out with no issue it appears the bolt threads into a rubber grommet with a metal thread sleeve insert.
Any help will be appreciated. I like doing simple stuff like this myself, but I want to do everything I can before I take it to a shop.
