So just a little back story, my motorcycle got stolen in September and recovered in December all messed up. I mean it was perfect, can't stand people these days, anyway. My headlight is gone as well as my front harness (cut right at gauge cluster). I recently purchased a new headlight assembly, LED H7 and H9 bulb. My main question is how do I connect the bulb to the harness? I also bought new mirrors with integrated blinkers and could use some advice on what wires to splice into, or a wiring diagram would be great. Any help would be great, pictures would be awesome (can't find any at all.) I am thinking I need an adapter in between the harness and connector for bulb. Thank you in advance! Be safe on the roads!
There are adapters available for fitting LED headlights, also double check the amperage necessary to power the light and change your fuse appropriately
Ok, awesome thank you. I found a video finally, the guy had a different brand than I bought but he had to break the connector on the harness in half. the connector on the bulb was a little too big. Are you talking about an adapter for the bulb itself? I spoke to a rep at JP Cycles and he said it would be a direct fit. I just for the life of me can't remember where on the harness it hooks up. All the ones I see on eBay had two small I believe gray connectors coming off of the loom just below the cluster connector.
Do you have a picture or link?
Is it just an LED bulb or is it a proper set of LED lights with ballasts?
