My 2007 gsxr 750 won't start. I turn the key hear the normal noise (fuel pump) and try to start and nothing happens. The battery is good. I tried to jump it with my car and still nothing. While the key is on I don't see f1 on the screen. I only see a red light. Before I put it in the shop I would like any suggestions. I think it's a switch or sensor but don't know wich one. Anyone have this problem b4?
You are pulling in the clutch while trying to start it, right?
Check all fuses.
What is your exact battery voltage?
If you are hearing the fuel pump prime, it is likely to be a charging system issue or a blown fuse.
