hello all got a 2007 gsxr 600 blew a head gasket back in 2015 and have been overseas since i replaced head gasket it will crank but not start. changed fuel spark plugs has spark on all 4, checked fuses(all good) replaced battery, replaced fuel pump(orginal wasnt priming), cleaned all 8 injectors(primary had corrision as well as got 12 volts on all), also cleaned both primary and secondary rails, no codes, tried starting with carb cleaning with air housing off nothing i do occasionally get pop or 2 from exhaust checked both cmp and ckp sensors reads good against the manual. and currently is stuck any help will help thanks in advance
Discussion Starter #2
i also
get a fireball from exhaust but with air housing off and cleaned all injectors still not spraying help!!
