Turned the key on. Bulb check was good. Pushed the starter and everything went black. Fuses are good and the battery tests at 12 volts. Any clues?
Bulb check doesn't say much. Did the tach sweep when you turned the power on? Did the fuel pump prime?
Your problem seems to be somewhat different but see #11 here.
Might just be a faulty battery. Measure the voltage as you try to crank.
