New: ecu, pump, fuses, relay, no codes.
While riding the engine just cut out, still had power still had gas it just cut out. I went over the bike and everything is fine except the injectors dont spray i broke the pump dont and cleaned and it despire being new and noting fuel in the rail it still has that new prime sound just no injector pulse. I can start it by putting gas in the throttle body but the bike will cut right back out wont even rev just bog down and dies please help
It's a 750? If so, you're in the wrong section.
Don't fully follow what you're saying. Have you done a fuel flow rate test?
