1 - 2 of 2 Posts
$5500 Firm
Full Superbike Stage-3 motor. Strong torque motor build for endurance. This is not just lightly massaged to Supersport spec.
Signed by Michael Jordan and Steve Rapp (+3hp)! Painted to honor 2004 Basketball Olympic Gold. This bike rips!
Pix here: https://photos.app.goo.gl/NFdRTxgXoNw6casNA
Dynoed on Sunoco 100 but runs 99.9% fine on 91/93 octane.
• SUPERBIKE MOTOR Stage-3 (~$6k): 185hp & 86 ft-lbs on Sunoco 100 PUMP FUEL, JE PISTONS, CARRILLO RODS, BALANCED CRANK, SLM PORTED HEAD, TITANIUM VALVES, WEB CAMS, APE HIGH OUTPUT OIL PUMP, CAM CHAIN TENSIONER, CAM SPROCKETS, WOODCRAFT CASE COVERS. Similar Stage-3 build here: https://www.kwsmotorsports.com/s1000.htm
• YOSHIMURA FULL RACE EXHAUST SYSTEM
• QUICK TURN THROTTLE w/ ADJUSTABLE CAMS. KEYLESS IGNITION
• OHLINS STEERING DAMPENER
• OHLINS FORK. 25mm CARTRIDGE. REFRESHED 4/2018. (200 lb rider)
• OHLINS SHOCK. REFRESHED 6/2015
• PVM MASTER CYLINDER, its trick
• R1 CALIPERS (steel pistons w/ no heat fade)
• BRAKETECH ROTORS
• REAR WAVER ROTOR
• POWER COMMANDER W/ QUICKSHIFTER
• WOODCRAFT REAR SETS
• SHORAI LITHIUM BATTERY
• CLEAN CA TITLE, NON-OP REGISTERED
• SPARES KIT, AFAM SPROCKETS, GRAVES FAIRING STAY, REAR SETS, Db KILLER, BLUE RACE BODYWORK SET (no tail), OEM ROTORS, MORE...
Mike in San Jose, CA
Nine72-83five-5315
racer_rr at hot mail .com
Discussion Starter #2
Spares (~$1000):
Upper & lower painted fairings
Spare rear set brackets, pegs, toe brackets
Yoshimura dB killer for Laguna
OEM sprockets, 5x
Clutch friction plates
Graves fairing stay
Graves swing arm shark fin
OEM master cylinder, levers, bolts, exhaust gaskets, spark plugs
1 - 2 of 2 Posts
