hmm, whats causing this? is it a wiring issue cutting the ignition off? fuel related? go thru the wiring very good, clutch sensor the works all connectors clean and pack with dielectric grease...
ignition? wiggle wires
Where is clutch sensor situated as a said new to this thanks for help though much appreciatedhmm, whats causing this? is it a wiring issue cutting the ignition off? fuel related? go thru the wiring very good, clutch sensor the works all connectors clean and pack with dielectric grease...
What's it idling at?
On the 600 K4 model, the clutch sensor should be on the clutch lever assembly..it is a such small switch that is activated when you pull in the clutch lever. 14 years ago, I was lost too, and I didn't know where to find it lolWhere is clutch sensor situated as a said new to this thanks for help though much appreciated
