2004 1k, fuel pump doesn\'t work
Washed the bike last weekend, normal method soapy water and garden hose to rinse off. The bike worked perfect prior to that event. Dried off the bike, rolled it into the garage. Today, the fuel pump does not turn on. The bike will crank and do everything else as normal, but no pump noise
So far the fuses, switches (clutch, side stand) etc. have been checked. What else could it be? Where is the fuel pump relay located on the bike?
Ryan
Re: 2004 1k, fuel pump doesn\'t work
Have you tried hooking up the battery directly to the fuel pump wire to see what happens? That would tell you alot right there..
Didn't you know, I buy one of each model every year...
It's Murphmonsters bike, I was posting for him because he's busy getting his new house taken care of.
Have not tried the direct hook up yet, I'll try that.
R
