Hey Guys/Gals,
This has been killing me for a while, the bike will always ride great for a half hour then it pops and shuts down, electronics stay on, CHECK comes on the dash, I have to let it sit for awhile then it fires back up for another half hour. I noticed the fuel pump doesn't spin up unless I let it sit then finally the CHECK goes off on its own. No codes thrown nor FI light. I replaced the following: Fuel pump and lines, Camshaft positioning sensor, spark plugs, wiring seems good, no corrosion on the ECU pins. Originally when this happened I got a C11 code so I replaced the sensor and boom code went away so did the light but the bike still does the same shit. Bike only has 5000 miles on it. I went through the fuel system and tested that. That checked out according to manual. Anyone else have this issue, its always happens at (give or take) 30 minute mark no matter the way I'm riding. Temp is varied at this point but it does it at 220, 170, 190C etc... so I don't think that has anything to do with it. I also have the kickstand sensor bypassed, I also bought a new battery and checked those connections and replaced them. Anyone ever experience this?
