Anyone know where I can get all the hardware for a stator. I need the stator and the bolts the hold it in. Pretty much everything except the rotor and the cover.
I may have a couple of extra ones laying around the shop from some blown up motors. If I have any i'll let you know.
Bearded Viking Admin...
eBay or a salvage shop - or Ron Ayers if you want new
here's a tip:
before you install it, carefully (so as not to damage any of the wiring) snip & remove those zip-ties that bind the output wires to the body of the stator. They become brittle over time, and create hot-spots that can lead to stator failure (IF you're replacing a bad stator as I assume you are - look at it closely. I'll bet money it scorched in the area of 1 or more of those zip-ties.
