1 - 2 of 2 Posts
· Premium Member
welp, we can offer advice how to diagnose so forth, things to check..
check for any vacuum leaks, sounds like you forgot to connect something here, otherwise it's a mapping issue in the ECU unless you managed to strangle the fuel supply without anything detecting this and compensating, sensor and vacuum leak?
go back over your work,inspect everything in the engine bay, vacuum hoses so forth, no pinched fuel line so forth, disconnected lines, you can check for codes as well, have you downloaded the service manual..
1 - 2 of 2 Posts
