1 - 1 of 1 Posts
Administrator
2000 Suzuki GSX-R600Y
Engine Type Four stroke, 4 cylinder, DOHC, 16 valve, TSCC, water cooled
Displacement 600cc
Bore & Stroke 65.5 x 44.5 mm
Compression Ratio 12.0:1
Carburetor Mikuni BDSR36, four
Lubrication Wet Sump
Ignition Digital electronic (DC-CDI)
Starter Electric
Transmission 6-speed, constant mesh
Final Drive Chain RK525 SMOZ x 108links
Overall Length 2065mm (81.3 in)
Overall Width 720mm (28.3 in)
Overall Height 1165mm (45.9 in)
Seat Height 830mm (32.7 in)
Wheelbase 1385 (54.5 in)
Ground Clearance 130mm (5.1 in)
Dry Weight 174kg (383 lbs)
Suspension (Front) Telescopic, coil spring, oil damped, adjustable spring preload, compression and rebound damping force
Suspension (Rear) Link type, coil spring oil damped, adjustable spring preload, compression and rebound damping force
Brakes Front-Hydraulic twin disc, Rear- Hydraulic, disc
Tires Front - 120/70 ZR17 (58W), Rear - 180/55 ZR17 (73W)
Fuel Tank Capacity 18.0L (4.0 imp gal)
Color Blue/white, Yellow/black, Alstare replica
2000 Suzuki GSX-R750Y
Engine Type Four stroke, 4 cylinder, DOHC, 16 valve, water cooled
Displacement 749cc
Bore & Stroke 72 x 46mm
Carburetor Electronic Fuel Injection, 2-52mm throttle bodies
Clutch Hydraulic
Starter Electric
Transmission 6-speed constant mesh
Final Drive Chain
Overall Length 2040mm (80.3 in)
Overall Width 717mm (44.6 in)
Overall Height 1134mm (55.5 in)
Seat Height 829mm (32.6 in)
Wheelbase 1410mm (55.5 in)
Dry Weight 166kg (366 lbs)
Suspension (Front) Inverted telescopic, coil spring, oil damped, adjustable spring preload, compression and rebound damping force
Suspension (Rear) Link type, coil spring, oil damped, adjustable spring preload, compression and rebound damping force
Brakes Front-Hydraulic twin disc, Rear Hydraulic, disc
Tires Front - 120/70 ZR17 (58W), Rear - 180/55 ZR17(73W)
[ 09-25-2001: Message edited by: admin ]
1 - 1 of 1 Posts
