1 - 12 of 12 Posts
i think i rememer the answers but..
1.. does a 1052 cyl head(rocker type) bolt right up to a 1127 motor..(91 shim)
wanting to get rid of the shim style head...
2.. im 99% sure a canadian 91 gsxr 1100 came with 40mm cv carbs.. true?
thanks
The other OG
WELL WHICH ONE IS IT ? WHO has done it ? i didn't think it swapped but didn't say so
anyone know about the head swap??
thanks for confirming the carb question!
since when does a 1052 head swap onto an 1127 without major machining and weldup work???
Get a B-12 head, its screw type adjustment and will bolt onto an 1127 ....
Discussion Starter · #7 ·
never heard of any welding/machining needed.??
Their is no difference between any year 1127 cylinder the head gasket is the same and if you say a bandit12 head will bolt on to a shim 1127 witch it will, i also know they bolt on to a 1052 block. I think you may be thinking of the 750's gg that's where some head swaps can require lots of work
Discussion Starter · #9 ·
just confirmed with JAY at APE...oil cooled guru..
any year 1100 head will go on,no mods needed..
only reason i want rid of the shim head,is camshaft selection..
thanks to all...
will be putting the 40mm CV carbs,with jet kit and K&N filter in stock airbox for sale soon...
I have an 86 1052 head, an 89-90 1127 head and a 91 1127 head and all three have identical gasket surfaces, the same cam sprockets and the same mounting holes. I can't see any reason you couldn't use any head on any motor.
You are right.. sorry. I,ve been on heavy drugs here lately since i got out of the hospital. I was thinking of the 750 swap indeed.....1100's are a breeze....
1 - 12 of 12 Posts
