So I'm on my 1st gen,1000 head removal, and I'm at the point where timing is next when removing the lower crank cover ,dose it screw in needing the corsponding torxs or is it one that snaps in and brakes easy ???any help pls and thxs
So I'm on my 1st gen,1000 head removal, and I'm at the point where timing is next when removing the lower crank cover ,dose it screw in needing the corsponding torxs od is if one that sbaps in and brakes easy ???any help pls and thxs
Oops you are right,I apologize,I have a manule true enough the answer will be in the book.but in the interest of getting to know the community I thought the question would open the doors to other thoughts ideas ect,ect,it's my first major over haul,any way the lower crank cap dose it un screw or is it a plastic cap that looks like it dose but doesn't? I'm trying to avoid braking it
