1 - 1 of 1 Posts
Administrator
1999 Suzuki GSX-R600X
Engine Type Four stroke, 4 cylinder, DOHC, 16 valve, TSCC, water cooled
Displacement 600cc
Bore & Stroke 65.5 x 44.5 mm
Compression Ratio 12.0:1
Carburetor Mikuni BDSR36, four
Lubrication Wet Sump
Ignition Digital electronic (DC-CDI)
Starter Electric
Transmission 6-speed, constant mesh
Final Drive Chain RK525 SMOZ x 108links
Overall Length 2065mm (81.3 in)
Overall Width 720mm (28.3 in)
Overall Height 1165mm (45.9 in)
Seat Height 830mm (32.7 in)
Wheelbase 1385 (54.5 in)
Ground Clearance 130mm (5.1 in)
Dry Weight 174kg (383 lbs)
Suspension (Front) Telescopic, internal cartridge type, adjustable spring preload, compression and rebound damping force
Suspension (Rear) Link type, gas/oil damped, adjustable spring preload, compression and rebound damping force
Brakes Front-Hydraulic twin disc, Rear- Hydraulic, disc
Tires Front - 120/70 ZR17, Rear - 180/55 ZR17
Fuel Tank Capacity 18.0L (4.0 imp gal)
Color Blue/white, Yellow/Black
1999 Suzuki GSX-R750X
Engine Type Four stroke, 4 cylinder, DOHC, 16 valve, water cooled
Displacement 749cc
Bore & Stroke 72 x 46mm
Compression Ratio 11.8:1
Carburetor Fuel Injection, 4 x 46mm throttle bodies
Clutch Hydraulic
Starter Electric
Final Drive Chain RK50MFOZ x 108 links
Wheelbase 1395 (54.9 in)
Dry Weight 179kg (394 lbs)
Suspension (Front) Inverted telescopic, internal cartridge type, adjustable spring preload, compression and rebound damping force
Suspension (Rear) Link type, gas/oil damped with piggyback reservoir, adjustable spring preload, compression and rebound damping force
Brakes Front-Hydraulic twin disc, Rear Hydraulic, disc
Tires Front - 120/70 ZR17, Rear - 190/50 ZR17
Color Blue/white, Red/Black
1 - 1 of 1 Posts
