Ordering a new fuel hose. I have a question
the fuel line I have is broken up into two green lines separated by a simple gravity on/off petcock. Don’t know why. Guy probably ran out of hose. ANYWAY
GETTING AN OEM fuel hose... is this the correct hose that goes from tank to carb? One hose, not two like my jig here.
thanks gurus.
Sam
573887
573888
Yes, no. 5 is the correct item.
However I would look into why the previous owner mounted the manual petcock in the first place... Most likely the original one is broken and causes flooding of the carbs.
Also: the underside of the fuel pump should be clean and dry, looks like something is leaking...
Thanks a bunch. Fuel pump gasket maybe? I’ll look into it
