1996 GSXR750 New Purchase
444 Views 22 Replies 4 Participants Last post by  Spduffee
4
TwistedMister asked me to post some photos of the new-to-me 750. I opened it up yesterday to see it, a '96, has fuel injection. Hmm. It runs and drives, though not great. I see the ECU is a 32900-33E01. The air box is from a carbie, too. Don'g know what the tank tells me, and I don't know what to look gor on thd harness or valve cover. I do know it's a 750 motor (the R...), but I don't see any way to decipher past the 2nd or 3rd digit. In looking at Ebay, just for the ECU, I'm looking at $100 to $250. Plus box, plus, plus, plus. I know my way around carbs, but not FI. Maybe it'd be best to find some carbs?
Automotive fuel system Motor vehicle Automotive exterior Auto part Rim
Automotive lighting Hood Grille Bumper Automotive exterior
Motor vehicle Automotive tire Fender Automotive exterior Bicycle part
Font Tints and shades Publication Gas Rectangle
1
1 - 20 of 23 Posts
Well this is embarrassing, and a relief at the same time. I mistook the setup for fuel injection, but it's not. Looking at it closer and at the manual, what I thought was a fuel rail and injectors are actually VTV's? This is all very new to me, but I'm glad I was wrong...Sorry gang...
Congrats 🍻. Gona get er up to snuff?
Btw theres an srad specific section on the forum under motorcycle specific.
Also, these will be handy:
Considerations:
https://www.roadstercycle.com/ (mosfet RR)
Thank you!
  • Like
Reactions: 1
Good stuff. I also have 96 SRAD 750 that I brought back to life. Lots of good info and advice on this site. Show us some pics of the bike!
3
Thanks, can't wait to get into this. It's got some issues, but nothing too bad, I think. Optically it's nice, with the plastic coveralls. Even those are beat up underneath. Oil leak, bad starter solenoid, front forks may need replaced, carbs cleaned (at least), valve clearances need checking, etc
Land vehicle Fuel tank Tire Wheel Vehicle
Tire Wheel Vehicle Automotive tire Automotive lighting
Wheel Tire Fuel tank Automotive fuel system Vehicle
  • Like
Reactions: 2
Like Scarlet Johanson without makeup...
Tire Wheel Fuel tank Vehicle Automotive lighting
pull that carb rack and disassemble all the way to jets and soak in yamahalube carb dip, 5-6 hours easy, then blow out with compressed air, all passage ways, soak again, 3 times do this, make sure jets are soaking as well or replace with new,
if you use the old you will have to polish the orifices.. easy enough if you have twine and some polish, coat the twine with polish, thread thru jet, secure both ends of twine the run the jet back and forth on the string spinning it so the orifice gets good and polished, maybe 2 stages of polish, really helps to keep em clean in the future and insure all residue is gone.
then when assembling pay strict attention to float height in that they are all the same and measured correctly, folks here can help with that, then insure all rings are good, gaskets and diaphragms are 100%, slides operate smoothly and not too loose and all needle clips are the same, follow base settings in service manual for clip settings and float height..
then bench sync the butterfly openings, videos on that on yootube, then sync with gauges while running,
check valve lash, timing marks, chain slack so forth, new plugs, new oil and filters she should run very well..
then go over tank, pump and petcock.. cleaning and replacing anything old or worn, crispy.. if tank is solid rust gunk evaporust will get her down to bare metal. some pump parts can be found still, fresh petcocks or rebuild kits, be sure your hoses are new, fuel line and you use good stock clamps for trouble free operation ..
Thank you for this! Sounds like a good way to spend 2 or 20 hours!
only part of it, next you go thru the wiring, celan all connectors and pack with dielectric grease, look for any melting bad connectors, inspect charging system maybe do a direct to battery inline fuse mod and mosfet R/R, Achilles for this bike, happens so much, at eh very least celan and pack with dielectric .. then a well adjusted manual cam chain tensioner should be good to go
Sorry, you lost me on this complete sentence, " maybe do a direct to battery inline fuse mod and mosfet R/R, Achilles". Can you describe each of these? I am not familiar with any of these...
Thank you for all the tips!
Went to check the oil and , wow! A lot of fuel in there. I had the same issue with my Wagoneer where the float needle got stuck. I'm guessing that is the problem. I saw the #1 carb was full of fuel, as it was on the kickstand, which seems like an excessive angle.
Am I right the petcock is vacuum activated, no on-off, no prime, etc? My Ninja is vacuum activated but it does have a prime button.
Anything else I should consider?
Thanks
Shawn
This link specifically ^
Mosfet rectifier upgrade. The oem ones tend to fry. Link has bundles with the other bits, such as a “in line fuse”. All to prevent cooking your harness/connectors when a rectifier and/or stator decides to cook the main harness. Sucks to deal with cooked/melted/brittle wiring. Go over it rite and never need to fuss with it again (or atleast not for several years).
Most issues in the srad section seem to usually be wiring problems from either butchery or rectifier frying… and carb or fueling issues.
Is good to get them solid anyway
Thanks
Shawn
Correct, just a vac petcock. Cobramadness sells good replacement ones if ya need 👍.
Sometimes the cylinder can land just rite and keep the vac pulled. If carbs are good to go, the carb should just fill and the float/float needle/float needle seat/ float needle seat o-ring,,, should stop fuel from hydrolocking the cylinder,,, meaning, even if the petcock is failed, the carbs (when working correctly) should be able to prevent fuel filing the cylinders.
If confident carbs are good and petcock is good… meaning kickstand lean actually to blame. You could put in a mid line valve onto the fuel line from tank to carbs. Then there’d never be an chance of issue anyway. But can be annoying to fuss with.
  • Like
Reactions: 1
When I lifted the tank and airbox, this came tumbling out. I looked for three ports missing something, but couldn't see anything needing a hose. Can anyone please describe where these go?
Nickel Bicycle part Metal Auto part Pipe
the single plugs into the front of the air box then the 2 plug into the top of the carbs, there are Tee's between carbs 1 and 2 and 3 and 4, or should be, check its all tight and good, not cracked up so forth, sealed well, it will run crappy if not when ram air tubes are connected ..
Oh, I think I saw those two nubs, and they weren't looking good at all. I'll take a look later on. Thank you for the info!
Yeah, they were hosed. I was able to create a makeshift solution. I'll take a look at CMSNL for part numbers.
Is there a writeup anywhere explaining the SRAD carbs and how they work? They are so different than any I have worked on. Then again, all the other bikes are from the 80's, except the '93 750SS. The reason I assumed it was a FI conversion was because of the sensor on the right hand side and the way the bowls are connected with what looks like a fuel rail. Weird - to me....
Found that my petcock leaks. That may be why fuel was pooled in the #1 cylinder (collecting in the lowest point in an exaggerated kickstand lean). I can get a new one cheaper than rebuilding.
  • Like
Reactions: 1
they equalize the pressure in the float bowls, something to do with the ram air, if you remove the ram air tubes them you can remove that hose set up, if you run ram air you need those, haven't really looked at the engineering but if you find a blueprint schematic of the carb I am sure you can work out whats going on..
there was a guy who recently found a solution for the Tee's using a different style, how they work is yet to be see but he just had to shave off the end of the single side and they fit, they were white ai thought? maybe the plumbing area of home dep? that thread shouldn't be too far down the SRAD section maybe 2nd page or so, it was just a week or so ago, he couldn't find any good new ones so he makeshifted em.. looked like a good set up, if its water plumbing then they should take heat for hot water so..
1 - 20 of 23 Posts
