1 - 20 of 58 Posts
Discussion Starter #13
I had a new hub machined for the PM wheel. I also used a Tyga brake caliper braket for a RGV-250 to eliminate the torque arm.
Next step is getting the custom pipes made.
Discussion Starter #16
I may redo the front end with these Ohlins forks from a Ducati 999r Xerox.
That's the problem with a build that takes so long, you tend to go in different directions.
The other OG
lookin good ,keep your unsprung weight down cause your kawa motor would be heaps less than a oiler, I'd mayby use rg250 front end and light swingarm
but should work ok with right suspension springs/valving
you know,,,,i happen to have the matching PM front wheel to that rear PM wheel,,it's an ex-Muzzy wheel off Scott Russell's bike,,,
1 - 20 of 58 Posts
