Well, the big day has finally happened. After 46 years, I FINALLY HAVE A GARAGE 😀 No more wrenching in random business parking lots or suffering in the cold. There are a bunch of things I need to do to the garage but it's a start. 20' x 20' and the wife is NOT allowed to park in it haha!
On the bike front, a few developments. Finally have my shock and cartridges back from Thermosman. If you need to have your cartridges re-valved or a Fox shock rebuilt, I can't recommend him enough! After having numerous issues with another vendor, he will be my go to guy moving forward for anything suspension oriented. I picked up a set of NOS fork tubes, lowers, and new springs. After almost a year of searching, I gave up trying to find a good set of 43mm forks to work with. I can't believe how much money I ended up investing in this front end. I also picked up a second Eibach spring for the stock linkage incase I don't use the SRS link out of the gate. Every single wear item on the Fox was replaced. Put a torrington bearing on it and machined up the preload collar to remove all the damage it had. I'm hoping to have the forks rebuilt this weekend. Also fitting a Shindy steering damper. This pretty much rounds out the suspension upgrades (minus the SPF swingarm which will come later).
Got my wheels powder coated semigloss white. New bearings and 2CT tires are ready for assembly. Should have this done in 3 weeks or so.
I removed the second look seat cover and reupholstered the front seat back to factory black. It was really easy to do, all you need is a good staple gun and 3D stretch seat fabric. Also, got my new windscreen in. You can still order them from Zero Gravity but it takes a couple months to get. Kinda wished I bought a spare.
Slow but steady progress. Now that I secured a garage, the bike will definitely be done for spring. Not sure if I will have it painted or not but it will be ready which is awesome.
