1 - 13 of 13 Posts
Does anyone know the stock 1/4 Mile time for an 88 gixxer 750?
How about the horsepower and torque ratings etc?
How about a guess at mine, it has a K&N filter, yosh cams, Yosh 4 into 1 Pipe, and jet kit?
Thanks...
[ 07-12-2002, 01:49 PM: Message edited by: 88 gixxer 750 ]
Get it on a dyno and find out for sure. Tune it and get to the track and see what you can make it do. But don't expect to break any records first time out.
You'll be back though because it's addictive as hell!
-Dave
from Cycle World February 1988
Price: $5199
Weight: 460lbs empty tank
491lbs full tank
Fuel capacity: 5.3gal
Wheelbase: 55.5in
rake/trail: 24.6deg/3.9in
Seat height: 31.3in
load capacity: 394lbs
bore and stroke: 73.0X44.8mm
displacement: 749cc
Compression ratio: 10.9:1
claimed power: 109hp/56.4lbs/[email protected]
valve adjustment interval: 4000miles
carburation: 4 X 36mm
oil capactiy: 6.1 quarts
final drive: 530 O-ring
final drive ratio: 15/45
Gear ratios:
1st: 13.96:1
2nd: 10.39:1
3rd: 8.38:1
4th: 7.06:1
5th: 6.18:1
6th: 5.52:1
Front forks: Showa 43mm
Travel: 4.7 in.
Adjustments: compression/rebound/preload
Rear suspension:Showa single shock
Travel: 5.5 in.
Adjustments: rebound/preload
Wheels: 3.5 X 17
4.5 X 17
tires: 120/70/17
160/60/17
Brakes: 2 X 12.2in. discs
1 X 9.4in. disc
Acceleration:
1/4 mile: [email protected]
0-30mph: 1.3 sec
0-40mph: 1.8 sec
0-50mph: 2.3 seo
0-60mph: 2.9 sec
0-70mph: 3.7 sec
0-80mph: 4.6 sec
0-90mph: 5.6 sec
0-100mph: 7.2 sec
Top Gear:
40-60mph: 4.7 sec
60-80mph: 4.7 sec
Top speed: 149mph
Engine speed at 60mph: 4950RPM
Fuel mileage:
High/Low/Avg: 45/42/43
Avg range(incl reserve): 222mi.
Braking distance:
30-0mph: 32ft.
60-0mph: 125ft.
Thanks for the response guys,
Hey karl_1052,
I though the 88 was 428Lbs dry, 460 is more than i though, oh well.
You would not happen to have that article scanned would you?? Anyone??
Thanks again...
Thanks again...
<font size="2" face="Verdana, Arial">428 is a weight advertised by Suzuki.
all manufacturers kinda cheat with their dry weight figures.
At that weght the manufacturers do not include such neccesities as fork oil, engine oil, air in tires, and other "luxuries".
the magazines report dry weight as the bike with an empty tank of fuel(a real world dry weight).
BTW, I am scheduling a big scanning session this weekend, so I will add that job to the pile.
Discussion Starter #7
Hey Karl,
That would be cool if you could scan that article. I would love to see what they said about the gixxer in 88.
Thanks Jason
Last time on a dyno, my '89 racebike with a V&H supersport pipe, K&N, Dyna Coils, and a jet kit posted 100bhp even. I had it on set of scales at the kart track after a race and it weighed 440lbs. Obviously, no lights and so on. The '89 is the short stroker though, isn't it, and the '88 the long? Thought it might be interesting for reference. Troy 341
what do you guys think the top speed is for an 89 with -1 front and +2 rear? ive put a full d+d exhuast and jet kit. my speedo broke but ive had the tach up to 12 grand in sixth.
<font size="2" face="Verdana, Arial">the 88 and 89 were both short stroke motors. they went back to the original B/S ratio in 1990.
Thanks, I couldn't remember if the short strokers were the '88, '89 or the '89, '90. Troy 341
1 - 13 of 13 Posts
