1 - 1 of 1 Posts
Administrator
1986 Suzuki GSX-R750
Engine Type
Four-stroke, DOHC, 16 valve, new twin swirl combustion chambers (TSCC), 4 cylinders, liquid (oil) cooled with Suzuki Advanced Cooling System (SACS)
Displacement
749cc
Bore & Stroke
70.0 mm x 48.7 mm
Compression Ratio
10.6:1
Carburetor
Mikuni VM29SS, four
Lubrication
Wet Sump
Ignition
Transistorized
Starter
Electric
Transmission
6-speed, constant mesh
Final Drive
# 530 chain, O-ring sealed
Overall Length
2115mm (83.3 in)
Overall Width
745mm (29.3 in)
Overall Height
1215mm (47.8 in)
Seat Height
795mm (31.3 in)
Wheelbase
1455mm (57.3 in)
Ground Clearance
125mm (4.9 in)
Dry Weight
176kg (388 lbs)
Suspension
Front: posi damp fork system (PDF) telescopic, coil spring oil damped, damper 4-way adjustable, spring preload 4-way adjustable, Rear: new full floater suspension system, oil damped, damper 4-way adjustable, spring preload, fully adjustable
Brakes
Deca Piston Front: disc brake, twin, hydraulically operated, Rear: disc brake, hydraulically operated
Tires
Front: 110/80VR 18 V240, radial, Rear: 140/70VR18 V240, radial
Fuel Tank Capacity
19.0L (4.2 lmp.gal.)
Color
Black/Red, White/Blue
1986 Suzuki GSX-R1100
Engine Type
Four-stroke, DOHC, 16 valves, new twin swirl combustion chambers, 4 cylinder, liquid (oil) cooled with Suzuki Advanced cooling system (SACS)
Displacement
1052cc
Bore & Stroke
76.0 mm x 58.0 mm
Compression Ratio
10.0:1
Carburetor
Mikuni BST34SS, four
Lubrication
Wet Sump
Ignition
Transistorized
Starter
Electric
Transmission
5-speed, constant mesh
Final Drive
# 532 O-ring sealed
Overall Length
2115mm (83.3 in)
Overall Width
745mm (29.3 in)
Overall Height
1215mm (47.8 in)
Seat Height
795mm (31.3 in)
Wheelbase
1460mm (57.5 in)
Ground Clearance
125mm (4.9 in)
Dry Weight
197kg (434 lbs)
Suspension
Front: telescopic, coil spring, oil damped, spring preload 4-way adjustable with Suzuki's new electrically activated suspension system (NEAS) Rear: new full floater suspension system, gas/oil damped, damper 4-way adjustable, spring preload, fully adjustable, remote reservoir
Brakes
Deca Piston Front: 310mm disc brake, twin, floating type, hydraulically operated, Rear: disc brake, hydraulically operated
Tires
Front: 110/80VR18 V260 radial, Rear: 150/70VR18 V260 radial
Fuel Tank Capacity
19.0L (4.2 lmp. gal.)
Color
Blue/Red, White/Blue
[ 06-22-2001: Message edited by: admin ]
1 - 1 of 1 Posts
