Hi, just got a project bike running and it's smoking a little. I thought I'd wait until it's ridden to see if the smoke clears to indicate stem seals or valves.
In the meantime I’ve checked my compression and it’s reading 105-110 across all 4, the manual says it should be 142-199 and that 114 requires attention (*crap). The apparent test to see if the issue is rings or valve related is to put a teaspoon of oil in, which I did in number 1 and the figure went up a little to 120.
Does this sounds like rings or valves or maybe both? I guess I can refurb the head but then idea if all that work and reassembly to find out it’s still low sounds
like a pain…
Thoughts?
like a pain…
Thoughts?
