Jeez guy,
I don't know.
Let me be your voice of reason/devils' advocate here.
First the bad news.
It's been awhile, but....
There were only two years that the buff didn't use the exhaust as a chain lubricator (you know I'm right). They always look like the back-end of a Corvair, or a Fiat X9.
If Moto-Guzzie made a 2 stroke 750 the engine would only weigh a few more pounds. the thing is huge and hefty.
Even though, the buff flowed more oil out the exhaust than a Texas stripper well they rotted.
Besides weighing a ton even without 5 gallons of 2 stroke oil in them they will be hard to find, since I recall them being a bit 'chambered' welding up a set at home is out of the question. There's a lot of metal there and connectors -also chrome but covered in burnt petroleum-.
Spoked wheels also well lubricated -black-.
God help you if the gauges/cables are wasted.
Where does one find a rebuild kit for the much acclaimed Suzuki auto injector pump, aka; CCI.
You need a small mountain of head gaskets for when you pull the heads off every 90 days to scrape the headchamber and piston top -that thing under all that greasy ass soot
. I believe the Mikuni's were rather tall for the day, undoubtedly rare. Parts jets/needles....
The throttle cables - even new - had what was called the 'short end' on the carb top (screw-on carb cap/top :<) ). This means be careful on adjustment -check full range of throttle-. If you don't, the short metal end covering the outer plastic cable will hang-up after a full throttle application then release. At the top of the carb, you'll see it if you look. Of course one cylinder only...
Brakes... when cleaned up the brakes are good looking. I can't remember if they were double leading linkage types or not.
They stopped the bike well but that frame and those shocks were even worse than the H-2. Point of fact as I recall the Buff even .... wobbles I guess is the word under hard acceleration. you know...like a Harley only with a good seat.
The forks were at best mediocore and at worse. Useless except to hang the wheel and fender on. depending on your weight and roads traveled the seals are all to ready to weep/leak.
Shocks...rides like a 62' Chrysler New Yorker with a 413ci hemi. Saying it rode like a fair sized cabin cruiser on a calm lake would be a little to kind , but hey, I'm being nice.
I do have to admit the exhaust note was something else. A smooth, burbble/gurgle, idle was always 'hunting' but sounded neat -I still do a fair imitation :<).
Radiator was solid but you gotta remmember they didn't have the aluminum friendly glycol back then and everyone added tap water... You'll have to pull her apart to see all the damage. Severe cases will leech-erode over to the cylinder walls. If so you'd have to mill at a minimum. Which would increse the compression to a place the engine walls, hardware, and it's internal weren't designed for.
But, my God Man! if memory serves... the paint on 77' was the much coveted, and sought after,Candy Pimp Purple tu-tone.
On the upside if you can get her runnin' you can keep her running. Like the 500 Titan, for real. I think the point cover was fairly tight so no leaks/rust but the point lobe did get a little ...ahem..rusty. I never had rectifier problems but that was damn near 30 years ago.
The side stand would sometimes let you down, never could figure that out.
Never park on hot/fresh asphalt.
Lights weren't an issue. But I think the switches and buttons will be toast by now...sorry.
Parts?
Fortuneatly, you see buff's all the time on e-bay - in the others section of Suzuki. Some look great but few are running.
If I had a museum I'd definitely want one on the floor -maybe even running- but basically they are yard art now.
Hell I'm trying to keep my son, Zack's 96' 750 Gixxer up to spec, and even though this is the best Gixxer site I could find there isn't much help for the OLD STYLE , carb'ed bikes and local shop help is LAME.
Even worse, I bought a cherry 92' 1100 GN -shaftie (screw those chains
also carb'ed and NOBODY WORKS ON THEM anymore.
If I was you I'd find a Suzuki 1100/1150 GS or E model for a restore at least they still have after-market stuff.
My 2 cents.
Good luck either way.
