The search function hasn't turned up much in the last 1 hour of searching. I'm debating on which size tire to order (Powers).
The basic understanding is that:
The 180/55 makes a bike steer quicker. It is also a bit taller which is why it makes a bike steer quicker. Also has more rubber on the sides. Less likely to roll off of the edges. Also typically $25 cheaper than the bigger 190/55. Minuses - Middle wears out quicker. Slight decrease in wheelieablity due to the slightly raised rear? Bike more twitchy and prone to tankslappers. Ideal for track days or canyon carving.
The 190/50 has a bigger contact patch in the middle and should last longer for commuting and be more stable for extended wheelies. More contact patch in rain or conditions where one can't lean over very far. Bike less prone to drifting and will feel more stable going straight. Minuses - $25 more, doesn't turn as quickly as the 180/55, could roll off of the edges if you're elbow-dragging, and weights more.
Did I get everything right? if not, what are the misconceptions that should be cleared up? Anything else that should also be taken into consideration?
Finally, which size should I get for a Turbo 1K2? Planning to try it out on a track day...
It's my 130 miles a day commuter too. I just can't seem to decide.
-Wicked
-Wicked
