1 - 2 of 2 Posts
Accurate Butt Dyno
I have an ‘87, replacing transmission gears as I have a number of issues with mine, wondering what other years I can draw from, some on eBay listed as 93-98, are the 86-92 different from the 93-98’s? Thanks for the help.
Also are the Bandit 1200 5 speeds interchangeable? If so what years?
I'm about to use a 91 model GXF1100 transmission to mate up with 1052 internals currently rebuilding. A lot of the transmissions can swap around but depends on the clutch as the 1052 didn't use a diaphragm clutch then there's lots of possibilities even a six speed which is often done. I think the only models that are difficult is the transmisions with the double row bearings from the 91-92 1127R
1 - 2 of 2 Posts
