Just turned over 1000 miles on my 750 gixxer. As far as the first service goes, should I take it to the dealer, they want almost $300. I just changed the oil, cleaned and lubed the chain, checked most of the bolts, checked the air cleaner and throttle/clutch linkage to make sure they didn't have too much play in the cables. Other than that, what else is important to check. I know the most important is to change the oil/clean, lube the chain which I have already done
