1 - 20 of 28 Posts
Where can I get just the "TUBE"...?
The R6 tube is about 1/5th the price of the adaptor...
The yamaha tubes are a MUCH better option
Go with the R6 tube for something close to a 1/5, or the R1 tube (which I like better) for something closer to a 1/6.
Both will be just a little shorter than the stock gixxer tube. Either trim your grip a little to compensate, or buy a grip that will fit the yami tube.
when you buy the yami tube it comes with a grip on it. they are like 11 bucks. and compaired to the plastic adapter they are smooth as hell.
im running the r1 tube right now.
the best place to get them waynesville cycle
R! 4YR-26240-01-00
R6 5EB-26240-00-00
waynesville
800 438 7921
Discussion Starter #7
Just remember i am still running stock clip-ons...
that should not matter the tube uses the stock throttle assembley
i have the tube with the plastic adapter if you want it
Discussion Starter #10
I'll just get a couple of tubes...No adapters for me...
ya'll know that RonAyers is a Yamaha dealer, right?
Discussion Starter #12
Yes, that is who'll I'll get it from...
So which tube feels better...R1 or R6...?
Me too. Like Wiz said, it doesn't really matter. But if you're running a stock throttle housing/kill switch, and you want the end of the throttle tube to line up with the end of the clip-on...
Simply drill another index hole in the clip-on down about 1/4" (measure it - I'm going off memory here) from the original. That's the hole that the throttle housing indexes on to keep it in one place on the clip-on.
I put the 1/5 on my 1000 and the 1/6 on my 600. Rather be hamfisted with the 600.
Discussion Starter #15
Note to self...Thanks
cut the tab off. i dont drill my clip on bars. they are bling bling carbon fiber
I put the R1 tube on (haven't ridden with it yet). It's cake to mount. It lines up OK. We're talking like 2mm here.
i did the R1 tube and all i have to say is
I LOVE IT
1 - 20 of 28 Posts
