1 - 8 of 8 Posts
I parked in the garage and turned it off, then turned it back on, the screen where the milage is on, only showed 8's and weird symbols, then sounded like an old lawnmower trying to start up or a car dieing cause of low battery, but then i checked the lights and they stayed on without dimming at all so i dont think its the battery any suggestions?
Does it crank slowly, similar to a car not getting enough power to crank the starter? Charge the battery fully and take it out for a ride.
Could be the stator or rectifier.
hi everyone i got 2007 gixer 600cc and i have the same problem
everything was fine till one day when i wanted to ride the bike and it wouldnt stay on
so i gave more gas for a lil and try again and it was fine.
but now after about a month it did it again i got a slip on exhaust big gun now and when i try to start the bike i need to give sum gas to keep it running
i was told it was the battery but no its not got new battery and same problem
new fuel in tank same problem
try starting the bike like 20 times and it did stay on for a lil and den i did it again was fine for a day next day it was okay i was on a bike for about 2hrs got vpower shell fuel and hit the highway.
came home left the bike overnite next day same thing wont stay on.....
anyone knows whats going on..???
no code or light :/
no code or light :/
Sounds like the bike isn't charging the battery. I had this same exact issue the last few months. First the stator went out (bike wouldn't stay on, wouldn't charge the battery), then the regulator/rectifier went out (wouldn't charge).
Hook up a multimeter to the battery and turn the bike on. Hold the RPMs around 4-5000, the multimeter should read ~14v.
As for Gixer07 -- If you've charged the battery (put it on a trickle charger or fast charger) and it still won't run then it's not the charging system. A bike can still run with a shot charging system... just until the battery runs out of juice.
We'd have to know the history of this bike to start making educated guesses. (Has it been taken care of? What were the last major services? How many miles? How hard/often is this ridden? Last sparkplug change? Last valve adjustment? Last airfilter change?)
I will say that I would expect the problem may stem from a low idle speed or spark plugs needing to be replaced.
Check this out, this is an excerpt from the service manual which I highly recommend you download. As you can see, there are a TON of things that can be causing problems, so the odds that someone on the internet can guess correctly are fairly low, but there are several people here who know what they're doing who might work with you.
Engine will not start or is hard to start.
Compression too low
1. Valve clearance out of adjustment
2. Worn valve guides or poor seating of valves
3. Mistiming valves
4. Excessively worn piston rings
5. Worn-down cylinder bores
6. Too slowly starter motor cranks (Note: this is in Engrish)
7. Poor seating of spark plugs
Plug not sparking
1. Fouled spark plugs
2. Wet spark plugs
3. Defective ignition coil
5. Defective CMP sensor
6. Defective CKP sensor
7. Defective ECM
8. Open-circuited wiring connections
No fuel reaching the intake manifold
1. Clogged fuel filter or fuel hose
2. Defective fuel pump
3. Defective CMP sensor
4. Defective fuel pressure regulator
5. Defective fuel injector
6. Defective fuel pump relay
7. Defective ECM
Incorrect fuel/air mixture
1. TP sensor out of adjustment
3. Defective fuel pressure regulator
4. Defective TP sensor
5. Defective CKP sensor
6. Defective IAP sensor
7. Defective ECM
8. Defective ECT sensor
9. Defective IAT sensor
10. Defective AP sensor
Engine idles poorly.
2. Poor seating of valves
3. Defective valve guides
4. Worn down camshafts
5. Too wide spark plug gaps
6. Defective ignition coil/plug caps
7. Defective CKP sensor
8. Defective ECM
9. Defective TP sensor
10. Defective fuel pump
11. Imbalanced throttle valve
12. Damaged or cracked vacuum hose
Engine stalls often.
1. Defective IAP sensor or circuit
2. Clogged fuel filter
3. Defective fuel pump
5. Defective ECT sensor
6. Defective thermostat
7. Defective IAT sensor
8. Damaged or cracked vacuum hose
Fuel injector improperly operating
1. Defective fuel injectors
2. No injection signal from ECM
3. Open or short circuited wiring connection
4. Defective battery or low battery voltage
Control circuit or sensor improperly operating
1. Defective ECM
2. Defective fuel pressure regulator
3. Defective TP sensor
4. Defective IAT sensor
7. Defective ECT sensor
8. Defective fuel pump relay
Engine internal parts improperly operating
2. Defective CKP sensor or ECM
3. Clogged fuel hose
4. Out of adjustment tappet clearance
Have a 09 gsxr 600, having starting iusse.i
have new everything, just installed a new ignition. Turn the key, and hear clicking/winding nosie...
Solutions???????
no code or light :/
Honestly it might sound stupid but have you adjusted your throttle? My 07 750 wouldn’t run all to well and then I turned the screw up a little and bumped up the rpms so it went back idling at around 1200-1500. It’s common in Az since we ride pretty much year round that to you have to tweak the throttle based on how hot/cold it is once or twice a year. There should be a screw on the clutch side right under where the throttle lines hook into the throttle body. It’s worth a shot.
1 - 8 of 8 Posts
