1 - 2 of 2 Posts
I bought this bike about two weeks ago, and have had problems with it since. It wouldn’t start when I went to go turn it on the lights started flicker and did the usual signs of a bad battery. So I swapped it out and it lasted me about two days till the problem started again. We thought maybe still this could just be another bad battery so we made sure and traded it out for another new battery. Now I realize it is not the battery, something is draining it completely to the point where it won’t even keep charge for a whole day. If I take it out for to long it’ll die on me and won’t start back up. When I hit the kill switch to turn it on itll either make a ticking noise and I won’t hear any of the priming being done. Or the priming will sound fine and then I’ll press the starter and all the lights will flick and it wont roll over at all. The ticking sound was coming from under the tank on the right side by the way. Please let me know if you have any suggestions
1 - 2 of 2 Posts
