Hi everyone I have a 07 GSXR 1000 And I'm having a bit of an issue My blinkers and my position light and my tell light a currently not working I replaced the fuses they all seem to be fine can anyone help me figure out what could possibly be the issue ?
"blinkers ... not working"
Front and rear? How about the horn?
That's very unusual and suggests a bad ground. Unplug the rear harness and measure the voltage from the Br lead on the main harness connector to ground. It should be 12 V when the ignition is on. Similarly the W/B lead is the brake light and should be 12 V when the ignition is on and a brake lever is pulled. It's not necessary but it would actually be better if you could make those measurements without unplugging the harness. Finally, put the ignition in Park (P) and see what lights come on.
